13.1 Lattice GC command reference
13.1.1 build uspline lattice
13.1.2 fold uspline lattice ref geom
13.1.3 export uspline lattice tessellation
13 Coreform Lattice GC
Coreform Lattice GC™ is a new product introduced in Coreform Cubit™ 2021.11 that implements Geometry-Compliant lattice structures. The geometry-compliant lattice structure technology defines the layout and shape of a lattice structure using a finite-element mesh into which a lattice is embedded. Each mesh element is assigned a lattice unit cell, and the element’s Jacobian applies a deformation to its unit cell which results in a deformed unit cell. In Coreform Lattice GC, a U-spline is used as the embedding mesh, enabling the construction of lattice structures with smooth intercellular interfaces and high-accuracy compliance to the CAD geometry on which the U-spline is built. Example workflows for building these lattice structures can also be found in the Cubit Workflows section under Building U-spline lattices.
This command will create and slice a U-spline lattice structure given an embedding U-spline mesh and a reference cell tessellation.
[build] uspline lattice <enum>ref_cell_tess <string>specifier base spline id <integer>id [j <integer>number_of_processors] [spsep <real>slice_plane_separation_value] [filename <string>cli_output_file_path] [filename for vtk vis <string>vtk_output_file_path] [filename for obj vis <string>obj_output_file_path] [tol <real>tolerance] [<boolean>visualize_only]
This command will partition the input geometry with planes defined by octahedaral symmetry and isolate the surfaces of the fundamental repeating unit into a group called “ folded_surfaces”.
fold uspline lattice ref geom <integer>volume_id [mesh <real>element_size]
This command will export the tessellation on surfaces in the input group to a JSON file.
export uspline lattice tessellation group name <string>group_name filepath <string>export_file_path
