10.4 Sample Journal Files
10.4.1 Example 1
reset create surface rectangle width 10 height 3 create surface circle radius 5 zplane surf 2 move z -10 create volume loft surface 1 2 delete surf 1 2 create boundary_layer 1 modify boundary_layer 1 uniform height 0.1 growth 1.2 layers 4 modify boundary_layer 1 add surface 4 volume 3 surface 5 volume 3 surface 6 volume 3 surface 7 volume 3 set boundary_layer intersection volume 3 curve 10 type side set boundary_layer intersection volume 3 curve 12 type side set boundary_layer intersection volume 3 curve 14 type side set boundary_layer intersection volume 3 curve 16 type side mesh vol 3
10.4.2 Example 2
reset create surf rectangle wid 2 cylinder rad .1 z .1 cylinder rad .02 z .1 section volume 2 xplane reverse section volume 3 xplane volume 3 move x .5 create volume loft surface 12 8 unite volume 2 3 4 vol 2 copy vol 5 scale .3 .3 1 vol 5 rotate -10 about z vol 5 move x .55 y -.1 vol 2 5 move x -.25 imprint all delete vol 2 5 surf all scheme trimesh group ’profile’ add curve 69 67 68 70 71 72 73 74 create boundary_layer 1 modify boundary_layer 1 uniform height 0.002 growth 1.2 layers 6 modify boundary_layer 1 add curve in group with name ’profile’ surface 36 curve in group with name ’profile’ size 0.02 surf 36 size .3 surface 36 sizing function linear neighbor 2 mesh surf 36
