10.2 Current Limitations
Not all combinations of intersection types and topology are supported for 3d cases. An end, corner, or reversal may not span multiple curves in a single volume. A possible workaround is to composite the curves to make a single curve. Not all meshing schemes may be used in combination with boundary layers. In cases where it is not supported, the boundary layer will be ignored in mesh generation.
Boundary layers are supported with the following schemes:
trimesh
pave
map
submap
sweep
tetmesh
