8.2 Adding Command Panels to the GUI
Users are able to create new command panels using https://www.qt.io/download, then add those panels to the navigation XML. The finished panels will be displayed along with the standard Cubit panels and will launch python scripts when the user clicks ’Apply’ or ’Preview’. This tutorial will show the reader how to add a command panel that creates a "Brick with Hole".
8.2.1 Create a directory to store command panels
Figure 488:
8.2.2 Create a directory for the new command panel
Figure 489:
8.2.3 Navigation Marker
Figure 490:
  • Save the XML file
    • Restart Cubit for the changes to take effect
  • The Brick with Hole panel will now appear in the button hierarchy but the panel will have no contents because we have not yet created a panel.ui file.
Figure 491:
8.2.4 Create Panel UI
Figure 492:
  • In Cubit, right-click on the panel where it says "No panel contents to display" and choose "Reset Data".
  • The new custom panel should now appear.
  • Tip: The panel.ui file is reloaded when "Reset Data" is executed. This allows you to modify the ui layout without restarting Cubit.
Figure 493:
8.2.5 Panel UI Widgets
8.2.5.1 Pick Widget
8.2.5.2 Pick Types
Geometry
  • Body
  • Volume
  • Surface
  • Curve
  • Vertex
  • Group
Exodus Containers
  • Nodeset
  • Sideset
  • Block
Mesh
  • Hex
  • Tet
  • Pyramid
  • Wedge
  • Quad
  • Tri
  • Edge
  • Node
  • BoundaryLayer
FEA Boundary Conditions
  • Acceleration
  • Velocity
  • Force
  • Pressure
  • Heatflux
  • Displacement
  • Temperature
  • Convection
  • ContactRegion
  • ContactPair
CFD Boundary Conditions
  • Axis
  • ExhaustFan
  • Fan
  • InletVent
  • InletMassflow
  • InletPressure
  • InletVelocity
  • IntakeFan
  • Interface
  • Interior
  • Outflow
  • OutletVent
  • OutletPressure
  • FarfieldPressure
  • Periodic
  • PeriodicShadow
  • PorousJump
  • Radiator
  • Symmetry
  • Wall
8.2.6 Apply Script
Figure 494:
  • Save apply.py, then in Cubit, set values for the brick size and cylinder radius in the panel and click "Apply" to create a brick with a hole in it.
Figure 495:
8.2.7 UserPanel Functions
8.2.8 Preview Script
