8.3.1 Importing an Existing Toolbar
8.3.2 Creating a New Toolbar
8.3.2.1 Creating a Command Panel Button
8.3.2.1.1 Use the definition dialog
8.3.2.1.2 Use the context menu on a command panel
8.3.2.1.3 Drag a command panel onto the toolbar
8.3.2.2 Creating a Journal File Button
8.3.2.3 Creating a Python Script Button
8.3.2.4 Creating a Basic Tool Button
8.3.2.5 Modifying an Existing Toolbar
8.3.3 Exporting a Toolbar
8.3 Workflows and Toolbars
Cubit provides users with the ability to create custom tool buttons. These custom buttons launch pre-defined journal or Python scripts.
Figure 496:
Figure 497:
  • Select Import from the context menu
Figure 498:
From this dialog a user may import an entire package containing multiple toolbars or a single toolbar. In this example we will import an entire package containing multiple toolbars.
Figure 499:
  • Select finish to complete the import.
Figure 500:
  • Select OK to finish the import
The new toolbar and buttons will be displayed as the last toolbar on the GUI. It is a docking window so it can be moved and placed anywhere on the GUI.
Figure 501:
  • Press the add button
  • Name the new toolbar and press OK
Figure 502:
  • Press the add button in the Buttons area
Figure 503:
A user may define 4 different types of toolbar buttons:
A Command Panel Button enables users to launch a command panel with the push of a button. A command panel button can be defined one of three ways:
Figure 504:
To find the Command Panel ID:
Figure 505:
Figure 506:
Figure 507:
  • The resulting toolbar looks like the following.
Figure 508:
All command panels include a context menu which can be accessed by clicking on an empty place in the command panel and using the mouse to show a context menu.
A Journal File Button will launch a journal file when pressed. The journal file may reside anywhere on the file system. A journal file button is defined by:
Figure 509:
Figure 510:
The "Basic" tool button has been available to Cubit users for many years. It contains a set of commands that execute when the user presses the button.
Figure 511:
Figure 512:
A user may want to share a toolbar, or a set of toolbars, with another user. This is easily accomplished.
Figure 513:
Figure 514:
  • In the next dialog, select the toolbars to be included in the export
  • Click Next on the dialog
Figure 515:
  • Optionally add files or folders that contain journal files or Python scripts referenced by tool buttons.
  • Click Finish in the dialog
  • Look for the .tar.gz file in the designated folder
Figure 516:
