11.6.1  Inheritance diagram for Body:
11.6  Body
Defines a body object that mostly parallels Cubit’s Body class. More...
#include <CubitInterfaceEx.hpp>
Public Member Functions
std::array< double, 3 >
get_mass_props ()
Get the mass properties of the Body, specifically the center of gravity. More...
int
point_containment (std::array< double, 3 > loc_in)
Get whether a point is in, on, or outside the Body. More...
double
volume ()
Get the volume of the Body. More...
bool
is_sheet_body ()
Get whether the Body is a sheet body or not. More...
Body (const Body &other)
Body (CubitEntity *entity_ptr)
Detailed Description
Defines a body object that mostly parallels Cubit’s Body class. Member Function Documentation
get_mass_props()
 std::array<double,3> get_mass_props ( )
std::array<double,3> props = body->get_mass_props();
Returns:
A vector (or list) of numerical data corresponding to the center of gravity of the body with indices as follows:
0 - x coordinate
1 - y coordinate
2 - z coordinate
is_sheet_body()
 bool is_sheet_body ( )
bool is_sheet = body->is_sheet_body();
is_sheet = body.is_sheet_body()
Returns:
Whether the Body is a sheet body or not
point_containment()
 int point_containment ( std::array< double, 3 >  loc_in)
std::array<double,3> point(3, 0);
int on_out_in = body->point_containment(point);
on_out_in = body.point_containment([0,0,0])
Returns:
Whether a point is unknown (-1), outside (0), in (1), or on (2) the Body
volume()
 double volume ( )
double vol = body->volume();
vol = body.volume()
Returns:
The volume of the Body
