11.7.1  Inheritance diagram for Volume:
11.7  Volume
Defines a volume object that mostly parallels Cubit’s RefVolume class. More...
#include <CubitInterfaceEx.hpp>
Public Member Functions
double
volume ()
Get the volume of the Volume. More...
void
color (int value)
Set the color of the Volume. More...
void
set_color (int value)
int
color ()
Get the color of the Volume. More...
std::array< double, 9 >
principal_axes ()
Get the principal axes of the Volume. More...
std::array< double, 3 >
principal_moments ()
Get the principal moments of the Volume. More...
centroid ()
Get the centroid of the Volume. More...
Volume (const Volume &other)
Volume (CubitEntity *entity_ptr)
Detailed Description
Defines a volume object that mostly parallels Cubit’s RefVolume class. Member Function Documentation
centroid()
 std::array<double,3> centroid ( )
std::array<double,3> centroid = volume->centroid();
centroid = volume.centroid()
Returns:
A vector (or list) of the coordinates of the centroid of the volume with the indices of the vector corresponding to the values as follows:
0 - x coordinate
1 - y coordinate
2 - z coordinate
color() [1/2]
 int color ( )
int col = volume->color();
col = volume.color()
Returns:
The color value associated with the volume’s current color
color() [2/2]
 void color ( int  value)
volume->color(0);
volume.color(0)
Parameters:
[in]
value
The color value that the volume will have
principal_axes()
 std::array<double,9> principal_axes ( )
std::array<double,9> axes = volume->principal_axes();
axes = volume.principal_axes()
Returns:
A vector (or list) of the principal axes of the volume with the indices of the vector corresponding to the values as follows:
0 - axis 1 x value
1 - axis 1 y value
2 - axis 1 z value
3 - axis 2 x value
4 - axis 2 y value
5 - axis 2 z value
6 - axis 3 x value
7 - axis 3 y value
8 - axis 3 z value
principal_moments()
 std::array<double,3> principal_moments ( )
std::array<double,3> moments = volume->principal_moments();
moments = volume.principal_moments()
Returns:
A vector (or list) of the principal moments of the volume with the indices of the vector corresponding to the values as follows:
0 - x moment
1 - y moment
2 - z moment
set_color()
 void set_color ( int  value)
volume->set_color(0);
volume.set_color(0)
Parameters:
[in]
value
volume()
 double volume ( )
double vol = volume->volume();
vol = volume.volume()
Returns:
The volume of the Volume
