11.17  Dir
Defines a direction object. More...
#include <CubitInterfaceEx.hpp>
Public Member Functions
Dir (double x, double y, double z)
double
x
Get the x location of the point. More...
double
y
Get the y location of the point. More...
double
z
Get the z location of the point. More...
void
set_x (double x_in)
Set the x location of the point. More...
void
set_y (double y_in)
Set the y location of the point. More...
void
set_z (double z_in)
Set the z location of the point. More...
std::array< double, 3 >
get_xyz
Get an array of the vector.
void
normalize
Normalize ’this’ vector. More...
void
set (double x, double y, double z)
Set the xyz values of the vector. More...
Dir
cross (Dir vec2)
Returns the cross product of thisXvec2. More...
double
dot (Dir vec2)
Returns the dot product.
double
length
Returns the length.
double
distance (Dir vec_in)
get the distance between two points
double
angle (Dir vec_in)
Returns the interior of two vectors. More...
void
dir_print
Print the output.
std::vector< CubitInterface::Dir
orthogonal_vectors
Finds 2 (arbitrary) vectors that are orthogonal to this one.
Public Attributes
double
xVal
double
yVal
double
zVal
Detailed Description
Defines a direction object. Member Function Documentation
angle()
 double angle ( Dir  vec_in)
return the angle is in radians
cross()
 Dir cross ( Dir  vec2)
Returns:
cross product
normalize()
 void normalize ( )
Returns:
void
set()
 void set ( double  x, double  y, double  z  )
Returns:
void
set_x()
 void set_x ( double  x_in)
Parameters:
x_in
the new x value
set_y()
 void set_y ( double  y_in)
Parameters:
y_in
the new y value
set_z()
 void set_z ( double  z_in)
Parameters:
z_in
the new z value
x()
 double x ( )
Returns:
x value
y()
 double y ( )
Returns:
y value
z()
 double z ( )
Returns:
z value
