11.9.1  Inheritance diagram for Curve:
11.9  Curve
Defines a curve object that mostly parallels Cubit’s RefEdge class. More...
#include <CubitInterfaceEx.hpp>
Public Member Functions
void
color (int value)
Set the color of the Curve. More...
void
set_color (int value)
int
color ()
Get the color of the Curve. More...
std::array< double, 3 >
tangent (std::array< double, 3 > point)
Get the tangent to the Curve at a particular point. More...
curvature (std::array< double, 3 > point)
Get the curvature of the Curve at a particular point. More...
closest_point (std::array< double, 3 > point)
closest_point_trimmed (std::array< double, 3 > point)
double
length ()
Get the length of the Curve. More...
curve_center ()
Get the center point of the Curve. More...
position_from_fraction (double fraction_along_curve)
Get the position of the point a specified fraction along the Curve. More...
double
start_param ()
Get the lowest value of the Curve in uv space. More...
double
end_param ()
Get the highest value of the Curve in uv space. More...
double
u_from_position (std::array< double, 3 > position)
Get the u value of a particular position on the Curve. More...
position_from_u (double u_value)
Get the position of a particular u value for the Curve. More...
double
u_from_arc_length (double root_param, double arc_length)
Get the u value for a point a specified arc length away from a specified root parameter on the Curve. More...
double
fraction_from_arc_length (Vertex root_vertex, double length)
Get the fraction along the Curve a specified arc length is away from a given Vertex. More...
point_from_arc_length (double root_param, double arc_length)
Get the position on a Curve that is a specified arc length away from the specified root parameter. More...
double
length_from_u (double parameter1, double parameter2)
Get the length between two specified parameters on a Curve. More...
bool
is_periodic ()
Get whether the Curve is periodic or not. More...
double
dihedral_angle (Curve other, Surface common_surface)
Get the dihedral angle between this curve and another curve relate to the given surface. More...
Curve (const Curve &other)
Curve (CubitEntity *entity_ptr)
Detailed Description
Defines a curve object that mostly parallels Cubit’s RefEdge class. Member Function Documentation
closest_point()
 std::array<double,3> closest_point ( std::array< double, 3 >  point)
std::vector<double> point(3, 0);
std::vector<double> close = curve->closest_point(point);
close = curve.closest_point([0,0,0])
Parameters:
[in]
point
A vector containing 3 doubles representing coordinates of a location on the Curve
Returns:
The closest point to the Curve from the location specified
closest_point_trimmed()
 std::array<double,3> closest_point_trimmed ( std::array< double, 3 >  point)
Parameters:
[in]
point
Returns:
color() [1/2]
 int color ( )
int col = curve->color();
col = curve.color()
Returns:
The color value associated with the curve’s current color
color() [2/2]
 void color ( int  value)
Parameters:
[in]
value
The color value that the curve will have
curvature()
 std::array<double,3> curvature ( std::array< double, 3 >  point)
std::vector<double> curvature = curve->curvature(point);
Parameters:
[in]
point
Returns:
The curvature of the Curve at the location specified
curve_center()
 std::array<double,3> curve_center ( )
std::array<double,3> center = curve->curve_center();
center = curve.curve_center()
Returns:
A vector containing the coordinates of the Curve’s center according to the following:
0 - x coordinate
1 - y coordinate
2 - z coordinate
dihedral_angle()
 double dihedral_angle ( Curve  other, Surface  common_surface  )
Parameters:
other
The other curve object that forms a dihedral angle with this one.
common_surface
Surface object that contains both curves.
Returns:
the dihedral angle between the curves, in radians
end_param()
 double end_param ( )
double end = curve->end_param();
Returns:
The ending value of the parameter
fraction_from_arc_length()
 double fraction_from_arc_length ( Vertex  root_vertex, double  length  )
double fraction = curve->fraction_from_arc_length(vertex, 0.5);
Parameters:
[in]
root_vertex
The Vertex to start from (vertex object)
[in]
length
The length along the Curve away from the root Vertex
Returns:
The fraction of the Curve that is the specified length away from the specified Vertex
is_periodic()
 bool is_periodic ( )
bool periodic = curve->is_periodic();
periodic = curve.is_periodic()
Returns:
Whether the Curve is periodic or not
length()
 double length ( )
double len = curve->length();
len = curve.length()
Returns:
The length of the Curve
length_from_u()
 double length_from_u ( double  parameter1, double  parameter2  )
double length = curve->length_from_u(0, 0.5);
Parameters:
[in]
parameter1
The beginning parameter
[in]
parameter2
The ending parameter
Returns:
The length between the two specified paramters along the Curve
point_from_arc_length()
 std::array<double,3> point_from_arc_length ( double  root_param, double  arc_length  )
std::vector<double> position = curve->point_from_arc_length(0, 0.5);
position = curve.point_from_arc_length(0, 0.5)
Parameters:
[in]
root_param
The root parameter from which the arc length is added to
[in]
arc_length
The arc length along the Curve away from the root parameter
Returns:
A vector that contains the coordinates of a position a specified arc length away from the root parameter
position_from_fraction()
 std::array<double,3> position_from_fraction ( double  fraction_along_curve)
std::array<double,3> pos = curve->position_from_fraction(0.5);
Parameters:
[in]
A decimal value between 0 and 1 to determine a particular position along the Curve
Returns:
A vector containing the coordinates of the position a specified fraction along the Curve:
0 - x coordinate
1 - y coordinate
2 - z coordinate
position_from_u()
 std::array<double,3> position_from_u ( double  u_value)
std::vector<double> position = curve->position_from_u(0.5);
position = curve.position_from_u(0.5)
Parameters:
[in]
u_value
The u value of the position along the Curve
Returns:
A vector containing the coordinates of the output position
set_color()
 void set_color ( int  value)
Parameters:
[in]
value
start_param()
 double start_param ( )
double start = curve->start_param();
start = curve.start_param()
Returns:
The beginning value of the parameter
tangent()
 std::array<double,3> tangent ( std::array< double, 3 >  point)
std::vector<double> tan = curve->tangent(point);
tan = curve.tangent([0,0,0])
Parameters:
[in]
point
Returns:
The tangent to the Curve at the location specified
u_from_arc_length()
 double u_from_arc_length ( double  root_param, double  arc_length  )
double u = curve->u_from_arc_length(0, 0.5);
Parameters:
[in]
root_param
The beginning parameter from which the arc length is added to
[in]
arc_length
The length away from the root parameter of the output parameter
Returns:
The u value of the Curve the arc length away from the root parameter
u_from_position()
 double u_from_position ( std::array< double, 3 >  position)
double u = curve->u_from_position(point);
u = curve.u_from_position([0,0,0])
Parameters:
[in]
position
A vector containing the coordinates of the input position
Returns:
