11.8.1  Inheritance diagram for Surface:
11.8  Surface
Defines a surface object that mostly parallels Cubit’s RefFace class. More...
#include <CubitInterfaceEx.hpp>
Public Member Functions
void
color (int value)
Set the color of the surface. More...
void
set_color (int value)
int
color ()
Get the color of the surface. More...
std::vector< std::vector< Curve > >
ordered_loops ()
Get the ordered loops of the Surface. More...
std::array< double, 3 >
normal_at (std::array< double, 3 > location)
Get the normal at a particular point on the Surface. More...
closest_point_trimmed (std::array< double, 3 > location)
Get the nearest point on the Surface to point specified. More...
closest_point_along_vector (std::array< double, 3 > location, std::array< double, 3 > along_vector)
Get the nearest point on the Surface to point specified along the specified vector. More...
closest_point_trimmed (CubitInterface::Loc location)
int
point_containment (std::array< double, 3 > point_in)
Get whether a point is on or off of the Surface. More...
std::array< double, 2 >
principal_curvatures (std::array< double, 3 > point)
Get the principal curvatures of the Surface. More...
position_from_u_v (double u, double v)
Get the Cartesian coordinates from the uv coordinates on the Surface. More...
u_v_from_position (std::array< double, 3 > location)
Get the uv coordinates from the supplied Cartesian coordinates on the Surface. More...
get_param_range_U ()
Get range of u for the Surface. More...
get_param_range_V ()
Get range of v for the Surface. More...
double
area ()
Get area of the Surface. More...
bool
is_planar ()
Get whether the Surface is planar or not. More...
bool
is_cylindrical ()
Get whether the Surface is cylindrical or not. More...
double
dihedral_angle (Surface other, double fraction)
Get the dihedral angle between this surface and another surface at a fraction along the shared curve between them. More...
Surface (const Surface &other)
Surface (CubitEntity *entity_ptr)
Detailed Description
Defines a surface object that mostly parallels Cubit’s RefFace class. Member Function Documentation
area()
 double area ( )
double area = surface->area();
Returns:
The area of the Surface
closest_point_along_vector()
 std::array<double,3> closest_point_along_vector ( std::array< double, 3 >  location, std::array< double, 3 >  along_vector  )
std::array<double,3> point(3, 0);
std::array<double,3> along_vector{1,1,1};
std::array<double,3> nearest = surface->closest_point_trimmed(point);
nearest = surface.closest_point_along_vector([0,0,0], [1,1,1])
Parameters:
[in]
location
A vector containing three values that are the coordinates of a point
Returns:
A vector (or list) of doubles representing values of nearest point as follows:
0 - x coordinate
1 - y coordinate
2 - z coordinate
closest_point_trimmed() [1/2]
 std::array<double,3> closest_point_trimmed ( CubitInterface::Loc  location)
nearest = surface.closest_point_trimmed([0,0,0])
Parameters:
[in]
location
Returns:
0 - x coordinate
1 - y coordinate
2 - z coordinate
closest_point_trimmed() [2/2]
 std::array<double,3> closest_point_trimmed ( std::array< double, 3 >  location)
Parameters:
[in]
location
Returns:
0 - x coordinate
1 - y coordinate
2 - z coordinate
color() [1/2]
 int color ( )
int col = surface->color();
col = surface.color()
Returns:
The color value associated with the surface’s current color
color() [2/2]
 void color ( int  value)
Parameters:
[in]
value
The color value that the surface will have
dihedral_angle()
 double dihedral_angle ( Surface  other, double  fraction  )
Parameters:
other
The other surface object used to form the dihedral angle
fraction
The fraction along the shared curve at which to calculate the dihedral angle (0.0 – 1.0)
Returns:
the dihedral angle between the surfaces, in radians
get_param_range_U()
 std::array<double,2> get_param_range_U ( )
std::vector<double> bounds = surface->get_param_range_U();
Returns:
The curvature values:
0 - The lowest value in the u direction
1 - The highest value in the u direction
get_param_range_V()
 std::array<double,2> get_param_range_V ( )
std::vector<double> bounds = surface->get_param_range_V();
lower_bound, upper_bound = surface.get_param_range_V()
Returns:
0 - The lowest value in the v direction
1 - The highest value in the v direction
is_cylindrical()
 bool is_cylindrical ( )
bool cyl = surface->is_cylindrical();
Returns:
Whether the Surface is cylindrical or not
is_planar()
 bool is_planar ( )
bool planar = surface->is_planar();
planar = surface.is_planar()
Returns:
Whether the Surface is planar or not
normal_at()
 std::array<double,3> normal_at ( std::array< double, 3 >  location)
std::array<double,3> norm = surface->normal_at(point);
norm = surface.normal_at([0,0,0])
Parameters:
[in]
location
Returns:
A vector (or list) of doubles representing values of normal vector as follows:
0 - x value
1 - y value
2 - z value
ordered_loops()
 std::vector<std::vector<Curve> > ordered_loops ( )
std::vector<std::vector<Curve> > loops = surface->ordered_loops();
Returns:
A vector of vectors (or list of lists) of Curves in loops:
0, 0 - loop 1 curve 1
0, 1 - loop 1 curve 2
1, 0 - loop 2 curve 1
etc...
point_containment()
 int point_containment ( std::array< double, 3 >  point_in)
int on_off = surface->point_containment(point);
on_off = surface.point_containment([0,0,0])
Parameters:
[in]
point_in
Returns:
A python boolean representing whether the point is off (0) or on (1) the Surface
position_from_u_v()
 std::array<double,3> position_from_u_v ( double  u, double  v  )
std::vector<double> pos = surface->position_from_u_v(0, 0);
Parameters:
[in]
u
The u parameter
[in]
v
The v parameter
Returns:
The Cartesian coordinates of the supplied uv coordinates as a vector:
0 - x coordinate
1 - y coordinate
2 - z coordinate
principal_curvatures()
 std::array<double,2> principal_curvatures ( std::array< double, 3 >  point)
std::vector<double> point(3, 0);
std::vector<double> curvatures = surface->principal_curvatures(point);
curvatures = surface.principal_curvatures([0,0,0])
Parameters:
[in]
point
Returns:
A list of two floats representing the curvatures
0 - curvature 1
1 - curvature 2
set_color()
 void set_color ( int  value)
Parameters:
[in]
value
u_v_from_position()
 std::array<double,2> u_v_from_position ( std::array< double, 3 >  location)
std::vector<double> location(3, 0);
std::vector<double> uv = surface->u_v_from_position(location);
Parameters:
[in]
location
A vector containing the Cartesian coordinates
Returns:
0 - The u parameter
1 - The v parameter
