5.5.1 Automatic Mesh Quality Assessment
5.5.2 Coincident Node Check
5.5.3 Controlling Mesh Quality
5.5.4 Metrics for Edge Elements
5.5.5 Finding Intersecting Mesh
5.5.6 Metrics for Hexahedral Elements
5.5.7 Mesh Quality Example Output
5.5.8 Mesh Quality Command Syntax
5.5.8.1 Quality Options
5.5.8.1.1 Draw
5.5.8.1.2 List
5.5.8.1.3 Filter
5.5.9 Metrics for Quadrilateral Elements
5.5.10 Metrics for Tetrahedral Elements
5.5.11 Mesh Topology Check
5.5.12 Metrics for Triangular Elements
5.5.13 Metrics for Wedge Elements
5.5 Mesh Quality Assessment
The "quality" of a mesh can be assessed using several element quality metrics available in Cubit. Information about the Cubit quality metrics can be obtained from the command
Quality Describe {Hex | Hexahedral | Tet | Tetrahedral | Face | Quad | Quadrilateral | Tri | Triangular}
which gives data on the quality metrics for each of the above element types. The following pages discuss the mesh quality assessment capabilities in Cubit.
Cubit performs an automatic calculation of mesh quality which warns users when a particular meshing scheme or other meshing operation has created a mesh whose quality may be inadequate. These warnings are supplied in case the user forgets to manually check the mesh quality.
Cubit automatically calculates the SHEAR quality of hexahedral and quadrilateral elements and the SHAPE quality of tetrahedral and triangular elements. The SHEAR metric measures element skew and ranges between zero and one with a value of zero signifying a non-convex element, and a value of one being a perfect, right-angled element. The SHAPE metric also ranges between zero and one with a value of zero signifying a degenerate or inverted element and a value of one signifying a perfect, equilateral element. The quality of the mesh is then defined to be the minimum value of the shear metric for hexahedral and quadrilateral elements and the shape metric for tetrahedral and triangular elements, with the minimum taken over the elements in the mesh.
If the quality of the mesh is zero, the code reports "ERROR: negative jacobian element generated" to the command window. By default, if the quality of the mesh is positive but less than a certain threshold, the code reports "WARNING: poorly-shaped element generated" to the command window. Also reported in this case is the ID of the offending element, the value of its shear (or shape) metric, and the value of the threshold to which it was compared. The default value of the threshold parameter is 0.2. Users may change the threshold value by issuing the command
Set Quality Threshold <double=0.2>
The user may also change what type of message is printed in the case of a poor quality, but positive Jacobian mesh. This message can be printed as a warning (the default) or an error or can be turned off completely using the command
Set Print Quality { WARNING|Error|Off }
The above commands only affect the message generated for meshes with a quality greater than zero and less than the given threshold value; an error will always be generated for meshes with a quality of zero (that is, for meshes containing negative Jacobian elements).
The ability to check for coincident nodes in the model is available in Cubit. It uses an efficient octal hash tree to make the comparisons.
To check for coincident nodes
  1. On the Command Panel, click on Mesh.
  2. Click on Volume, Surface, Curve, Vertex or Group.
  3. Click on the Quality action button.
  4. Select Coincidence Check from the drop-down menu.
  5. Select Coincident Nodes from the Type of Coincidence Check menu.
  6. Enter the appropriate settings.
  7. Click Apply.
Quality Check Coincident Node [ In ] [Group|Body|Volume|Surface|Curve|Vertex <id_range> ] [ Merge [Delete] ] [ HIGHLIGHT|Draw [color <number>]] [List] [Into Group [names|id] ]
If no entity list is given, the command works on all the nodes in the model. If an entity list is given, then it compares the nodes on those entities with the rest of the nodes in the model. By default the command highlights the coincident nodes in the graphics window and lists the total number of coincident nodes found. You can also have it clear the graphics and draw the nodes, and/or list the coincident node ids. Optionally, the coincident nodes found can be placed in a group.
If the model being operated on is from an imported universal file (i.e., no geometry exists in the model), you can merge the coincident nodes with the merge option. In this case delete allows you to delete the extra nodes (recommended). If you do not delete them they are placed into an output group.
You can control the tolerance used to check between nodes with the following setting (default = 1e-8):
set Node Coincident Tolerance [<value>]
If the quality of a model after meshing isn’t acceptable, there are two options available to improve that quality. The user can ask for more smoothing, or delete the mesh and start over. There are some commands that the user can invoke before meshing the model which can help to improve mesh quality. Some of them are discussed here.
5.5.3.1 Skew Control
The philosophy behind the skew control algorithm is one of subdividing surfaces into blocky, four-sided areas which can be easily mapped. The goal of this subdivide-and-conquer routine is to lessen the skew that a mesh exhibits on submapped regions. By controlling the skew on these surfaces, the mesh of the underlying volume will also demonstrate less skew.
To control skew or delete skew control
  1. On the Command Panel, click on Mesh and then Surface.
  2. Click on the Control Skew action button.
  3. Select Control Skew or Delete Control Skew from the drop-down menu.
  4. Enter the appropriate value for Surface ID(s). This can also be done using the Pick Widget function.
  5. Click Apply.
Control Skew Surface <surface_id_range> [Individual]
Delete Skew Control Surface {surface_list} [Propagate]
The keyword individual is deprecated. Its purpose is to specify that surfaces should be processed without regards to the other surfaces in the given list. This is not necessary, and could lead to problems with the final mesh. When the command is entered, the algorithm immediately processes the surfaces, inserting vertices and setting interval constraints on the resulting subdivided curves. In this way, the mesh is more constrained in its generation, and the resulting skew on the model can be lessened. The only surfaces that can utilize this algorithm are those that lend themselves to a structured meshing scheme, although future releases might lessen this restriction.
The user also has the ability to delete the changes that the skew control algorithm has made. This is done by using the delete skew control command.
When the user requests the deletion of the skew control changes on a given surface, every curve on that surface will have the skew control changes deleted, even if a given curve is shared with another surface on which skew control was performed. If the user wishes to propagate the deletion of skew control to all surfaces which are affected by one (or more) particular surfaces, the keyword propagate should be used.
5.5.3.2 Propagate Curve Bias
When a bias mesh scheme is applied to a curve, this sometimes creates skewing of the surface mesh that is attached. Sometimes the user will want to ensure that the same bias is applied to curves on attached surfaces so that this skewing is minimized.
To propagate curve bias
  1. On the Command Panel, click on Mesh and then Curve.
  2. Click on the Mesh action button.
  3. Enter the appropriate value for Select Curves. This can also be done using the Pick Widget function.
  4. Select Bias from the first drop-down menu.
  5. Select Propagate Curve Bias from the second drop-down menu.
  6. Select Volume, Surface or Group from the third drop-down menu and enter the appropriate settings.
  7. Click Apply and then Mesh.
Propagate Curve Bias [Surface|Volume|Body|Group <id_list>]
This command will search out all simply mappable surfaces in the input list, find which curves of those have a bias scheme set, and will propagate that bias across the mappable surfaces.
5.5.3.3 Adjust Boundary
To adjust a boundary
  2. Click on the Adjust Boundaries action button.
  3. Enter the appropriate value for Surface ID(s). This can also be done using the Pick Widget function.
  4. Enter the appropriate value for Angle.
  5. Click Apply.
Adjust Boundary {Surface|Group} <id_range> [Angle <double>]
This command can be used to improve element quality for mapped or submapped surface meshes. Often, due to vertex positions, the curve meshing for a surface will lead to a poor quality surface mesh. This command can be used to adjust the curve meshes in an attempt to generate a better quality surface mesh. The command works by looking at the angle the mesh edges leave the boundary. In a perfect mapped or submapped mesh, the mesh edges will be orthogonal to the boundary, or will go off at 90 degree angles. The adjust boundary command looks at the deviation of the mesh edges, and if it is greater than the prescribed angle deviation, it will move the node location such that it is 90 degrees, if possible. The deviation angle by default is 5 degrees and can be changed by the user through the [angle <double>] option in the command. In order to modify the curve meshes, the surface meshes are first deleted then later remeshed after the curve meshes have been repositioned and fixed. This command assumes that the volumes attached to the surface have not been meshed, if they have been, the command will return an error message. It should be noted that this command, while useful, may not always work due to interval constraints (i.e., you may need to change the intervals on the surface), or if the surfaces are not very blocky.
The metrics used for edge elements in Cubit are summarized in the following table:
Function Name
Dimension
Full Range
Acceptable Range
Length
L^0
0 to inf
None
5.5.4.1 Quality Metric Definitions:
Length: Distance between beginning and ending nodes of an edge
5.5.4.2 Comments on Algebraic Quality Measures
  1. The quality command for edge length only accepts edge elements as input; it does not accept geometry as input.
  2. The length metric is currently only available for edge elements. Edge elements are created by default when curves and surfaces are meshed. Edge elements are not created for interior volume elements.
The find mesh intersection capability finds intersecting mesh between blocks, bodies, volumes, or surfaces. This command is useful for identifying cases where the geometry does not intersect but the mesh does. The command can find intersecting 2-dimensional mesh by specifying a list of surfaces, or 3-dimensional mesh by specifying blocks, bodies, or volumes. Surfaces that have mesh between them that intersects within a tolerance of 1e-6 are located. Finding surfaces with intersecting mesh is done using the command:
Find Mesh Intersection {Block|Body|Surface|Volume} <id_list> [with {Block|Body|Surface|Volume} <id_list>] [low <value=0.0001>] [high <value>] [exhaustive] [worst <num_worst>] [draw] [log] [group<’name’>]
5.5.5.1 Finding Intersecting 2D Mesh
To find intersections between 2-dimensional mesh surfaces must be specified. If intersections are found, the surfaces containing the intersecting mesh are drawn (Figure 361) and the put into a group named ’surf_intersect’, unless the user has specified another name using the group <’name’> option. Also, the ids of the intersecting surface pairs are printed to the terminal,
Figure 361: "Find mesh intersection surface all"
The draw option will draw the surfaces and intersecting mesh in wire frame mode, allowing the user to see exactly where on the surface the mesh intersection is (Figure 362).
Figure 362: "Find mesh intersection surface all draw"
5.5.5.2 Facetted Representation
Detecting mesh intersections between surfaces works entirely off of the mesh, converting the mesh into triangular facets. (The facetted representation is what you see in a shaded view in the graphics). For example, a quad is split into two triangles. Higher order 2D elements are split into multiple triangles.
5.5.5.3 Drawing Mesh Intersection
The command below will draw the mesh intersection for only a pair of surfaces. The surfaces and intersecting mesh are drawn in wire frame mode, allowing the user to see exactly where on the surface the mesh intersection is.
Draw Surface <id> <id> mesh intersection [add] [include_volume]
Figure 363: Draw Mesh Intersection
5.5.5.4 Finding Intersecting 3D Mesh
With 3-dimensional entities mesh element intersections can be located by specifying entities: blocks, bodies, or volumes. If intersections are found the intersecting elements are put into a group named ’mesh_intersect’ unless the user has specified another name using the group <’name’> option. Data is printed to the terminal detailing the intersections. The largest intersection value is reported for each pair of intersecting entities (blocks, volumes, or bodies). This value is the fraction of an element’s volume (which element belongs to the entity in the first column) that intersects elements belonging to the entity in the second column. See Figure 364 below. The information printed in columns from left to right is:
  • the entities that have intersecting mesh
  • the other entities with which that entity’s mesh intersects
  • the highest intersection value of an element belonging to the entity in column one
  • the id of that element
  • the number of elements of the entity in column one intersecting other elements of the entity in column two
Figure 364: "Find mesh intersection block all draw"
If the with option is used, the user specifies additional entities. The additional entities will not be reported in the first column of the output. This allows the user to focus on entities of interest without outputting too much data to the terminal. See Figure 365 below.
Figure 365: "Find mesh intersection block 1 with block all"
The low and high options set how much cumulative intersection should be detected. A low value of 0.1 would ignore elements that do not intersect more than 10% of their volume. Similarly, a high value of 0.5 would discard elements that intersect more than 50% of their volume. Both low and high can be used simultaneously. The default for the low value is 0.0001
The exhaustive option examines all elements for intersection. The default is to only examine elements with nodes on the boundary of the specified entities, anticipating that the intersections will occur mostly at boundaries.
The worst parameter limits the printout to the ’n’ worst entities with elements of the highest intersections. The intersection fraction reported here is the cumulative intersection an element has with elements of all other entities in the check.
The draw option draws the intersecting elements using a color spectrum, red corresponding to high intersection and green to low. The color is according to cumulative intersection, as described in the worst option.
If the log option is specified, the output from the command will also be sent to a file named "mesh_intersection01.txt", with the number used in the file name incremented as needed. This becomes useful when you have hundreds of volumes with intersections.
Note:
The metrics used for hexahedral elements in CUBIT are summarized in the following table:
Function Name
Dimension
Full Range
Acceptable Range
Reference
Aspect Ratio
L^0
1 to inf
1 to 4
1
Skew
L^0
0 to 1
0 to 0.5
1
Taper
L^0
0 to +inf
0 to 0.4
1
Element Volume
L^3
-inf to inf
None
1
Stretch
L^0
0 to 1
0.25 to 1
2
Diagonal Ratio
L^0
0 to 1
0.65 to 1
3
Dimension
L^1
0 to inf
None
1
Condition No.
L^0
1 to inf
1 to 8
5
Jacobian
L^3
-inf to inf
None
5
Scaled Jacobian
L^0
-1 to +1
0.5 to 1
5
Shear
L^0
0 to 1
0.3 to 1
5
Shape
L^0
0 to 1
0.3 to 1
5
Relative Size
L^0
0 to 1
0.5 to 1
5
Shear & Size
L^0
0 to 1
0.2 to 1
5
Shape & Size
L^0
0 to 1
0.2 to 1
5
Timestep
Seconds
0 to inf
None
6
Distortion
L^0
0 to 1
0.6 to 1
7
5.5.6.1 Hexahedral Quality Definitions
With a few exceptions, as noted below, Cubit supports quality metric calculations for linear hexahedral elements only. When calculating quality metrics, that only support linear elements, for a higher order hexahedral element, Cubit will only use the corner nodes of the element.
Aspect Ratio: Maximum edge length ratios at hex center.
skew: Maximum |cos A| where A is the angle between edges at hex center.
taper: Maximum ratio of lengths derived from opposite edges.
element volume: Jacobian at hex center.
stretch: Sqrt(3) * minimum edge length / maximum diagonal length.
diagonal ratio: Minimum diagonal length / maximum diagonal length.
dimension: Pronto-specific characteristic length for stable timestep calculation. Char_length = Volume / 2 grad Volume.
condition no. Maximum condition number of the Jacobian matrix at 8 corners.
jacobian: Minimum pointwise volume of local map at 8 corners at center of hex. Cubit also supports Jacobian calculations for hex27 elements.
scaled jacobian: For linear elements the minimum Jacobian divided by the lengths of the 3 edge vectors.
shear: 3/Mean Ratio of Jacobian Skew Matrix
shape: 3/Mean Ratio of weighted Jacobian Matrix
relative size: Min(J, 1/J), where J is the determinant of weighted Jacobian matrix
shear & size: Product of Shear and Size Metrics
shape & size: Product of Shape and Size Metrics
timestep: The approximate maximum timestep that can be used with this element in explicit transient dynamics analysis. This critical timestep is a function of both element geometry and material properties. To compute this metric on hexes, the hexes must be contained in a element block that has a material associated to it, where the material has poisson’s ratio, elastic modulus, and density defined.
distortion: {min(|J|)/actual volume}*parent volume, parent volume = 8 for hex. Cubit also supports Distortion calculations for hex20 elements.
5.5.6.2 References for Hexahedral Quality Measures
  1. (Taylor, 89)
  2. FIMESH code
  3. Unknown
  4. (Knupp, 00)
  5. P. Knupp, Algebraic Mesh Quality Metrics for Unstructured
    Initial Meshes, to appear in Finite Elements for Design
    and Analysis.
  6. Flanagan, D.P. and Belytschko, T., 1984, "Eigenvalues and Stable Time Steps for the Uniform Hexahedron and Quadrilateral," Journal of Applied Mechanics, Vol. 51, pp.35-40.
  7. SDRC/IDEAS Simulation: Finite Element Modeling - User’s Guide
The typical summary output from the command quality surface 24 is shown in Figure 366. Figure 2 shows the corresponding histogram. The colored element display resulting from the command quality surface 1 draw ‘skew’ is shown Figure 368. A color legend is also printed to the console as shown in Figure 367.
Figure 366: Typical Summary for a Quality Command
Figure 367: Legend for command "Quality Surface 1 Skew Draw Mesh"
Figure 2. Histogram output from command "Quality Surface 24 Draw Histogram"
Figure 368: Graphical output of quality metric for command "Quality Surface 24 Skew Draw Mesh"
To view the quality of a mesh
  2. Click on Volume or Surface.
  4. Select Quality Metrics from the drop-down menu.
  5. Enter the appropriate value for Volume ID(s) or Surface ID(s). This can also be done using the Pick Widget function.
  6. Specify the Quality Metric type to view from the Quality Metric drop-down menu.
  7. Select Display Graphical Summary.
  8. Click Apply.
Quality {geom_and_mesh_list} [metric name] [quality options] [filter options]
Where the list contains surfaces and volumes and groups that have been meshed with faces, triangles, hexes, and tetrahedra; the list can also specify individual mesh entities or ranges of mesh entities.
If a specific metric name is given, only that metric or metrics are computed for the specified entities. Note that the metric given must be one which applies to the given entities. To see a list of quality metrics for individual entities see the Mesh Quality Assessment section and select the desired entity type: hexahedral, tetrahedral, quadrilateral, triangle. or edge
The metric name can also be more general than a specific metric. Four generalized options for metric name can be used:
allmetrics: All of the metrics corresponding to the element type of the geom_and_mesh_list will be computed and reported.
algebraic: All algebraic metrics corresponding to the element type of the geom_and_mesh_list will be computed and reported (e.g., Shape, Shear, Relative Size).
robinson: All Robinson metrics corresponding to the element type of the geom_and_mesh_list will be computed and reported (e.g., Aspect Ratio, Skew, Taper).
traditional: All the traditional Cubit metrics corresponding to the element type of the geom_and_mesh_list will be computed and reported (e.g., area, volume, angle, stretch, dimension).
If no metric name is supplied, the default metric is "shape".
The quality options are:
[ Global | Individual ]
If the user specifies individual, one quality summary is generated for each entity specified on the command line. If the user specifies global, or specifies neither, then one quality summary is generated for each mesh element type.
5.5.8.1.1 Draw
[ Draw [Histogram] [Mesh] [Monochrome] [Add] ]
If the user specifies draw histogram, then histograms are drawn in a separate graphics window. The window contains one histogram for each quality metric. If the user specifies draw mesh, then the mesh elements are drawn in the default graphics window. A color-coded scale will appear in the graphics window. The histogram and mesh graphics are color coded by quality: a small metric value corresponds to red, a large metric value to blue and in-between values according to the rainbow. You can grab the side of color bar and resize it.The text gets smaller as the color bar width decreases.You can also grab in the middle of thecolor bar and move it around.It can be repositioned to the bottom ortop and it will automatically change orientations. See Figure 369.
Figure 369: Quality Scale
If monochrome is specified, then the graphics are not color-coded. If add is specified, then the current display is not cleared before drawing the mesh elements.
5.5.8.1.2 List
[ List [Detail] [Id] [Verbose Errors] ] [Geometry]
If the user specifies list, then the quality data is summarized in text form. list detail lists the mesh elements by ascending quality metric. list id lists the ids of the mesh elements. If verbose errors is specified, then details about unacceptable quality elements are printed out above the summaries. If geometry is specified, then a list of the geometric entities that own the elements will be printed.
5.5.8.1.3 Filter
There are several options available to filter the output of the quality command, using the following filter options :
[High <value>] [Low <value>]
Discards elements with metric values above or below value; either or both can be used to get elements above or below a specified value or in a specified range.
[Top <number>] [Bottom <number>]
Keeps only number elements with the highest or lowest metric values. For example, quality hex all aspect ratio top 10 would request the elements with the 10 highest values of the aspect ratio metric.
The metrics used for quadrilateral elements in Cubit are summarized in the following table:
Function Name
Dimension
Full Range
Acceptable Range
Reference
Aspect Ratio
L^0
1 to inf
1 to 4
1
Skew
L^0
0 to 1
0 to 0.5
1
Taper
L^0
0 to +inf
0 to 0.7
1
Warpage
L^0
0 to 1
0.9 to 1.0
NEW
Element Area
L^2
-inf to inf
None
1
Stretch
L^0
0 to 1
0.25 to 1
2
Minimum Angle
degrees
0 to 90
45 to 90
3
Maximum Angle
degrees
90 to 360
90 to 135
3
Condition No.
L^0
1 to inf
1 to 4
4
Jacobian
L^2
-inf to inf
None
4
Scaled Jacobian
L^0
-1 to +1
0.5 to 1
4
Shear
L^0
0 to 1
0.3 to 1
5
Shape
L^0
0 to 1
0.3 to 1
5
Relative Size
L^0
0 to 1
0.3 to 1
5
Shear & Size
L^0
0 to 1
0.2 to 1
5
Shape & Size
L^0
0 to 1
0.2 to 1
5
Distortion
L^2
-1 to 1
0.6 to 1
6
5.5.9.1 Quadrilateral Quality Definitions
aspect ratio: Maximum edge length ratios at quad center
skew: Maximum |cos A| where A is the angle between edges at quad center
warpage: Cosine of Minimum Dihedral Angle formed by Planes Intersecting in Diagonals
element area: Jacobian at quad center
stretch: Sqrt(2) * minimum edge length / maximum diagonal length
minimum angle: Smallest included quad angle (degrees).
maximum angle: Largest included quad angle (degrees).
condition no. Maximum condition number of the Jacobian matrix at 4 corners
jacobian: Minimum pointwise volume of local map at 4 corners & center of quad
scaled jacobian: Minimum Jacobian divided by the lengths of the 2 edge vectors
shear: 2/Condition number of Jacobian Skew matrix
shape: 2/Condition number of weighted Jacobian matrix
relative size: Min( J, 1/J ), where J is determinant of weighted Jacobian matrix
shear and size: Product of Shear and Relative Size
shape and size: Product of Shape and Relative Size
distortion: {min(|J|)/actual area}*parent area, parent area = 4 for quad
5.5.9.2 Comments on Algebraic Quality Measures
Shape, Relative Size, Shape & Size, and Shear are algebraic quality metrics that apply to quadrilateral elements. Cubit encourages the use of these metrics since they have certain nice properties (see reference 5 below). The metrics are referenced to a square-shaped quadrilateral element, thus deviations from a square are measured in various ways.
Shape measures how far skew and aspect ratio in the element deviates from the reference element.
Relative size measures the size of the element vs. the size of reference element. If the element is twice or one-half the size of the reference element, the relative size is one-half. The reference element for the Relative Size metric is a square whose area is determined by the average area of all the quadrilaterals on the surface mesh under assessment
Shape and size metric measures how both the shape and relative size of the element deviate from that of the reference element.
The SHEAR metric is based on the condition number of the skew matrix. SHEAR is really just an algebraic skew metric but, since the word skew is already used in the list of quad quality metrics, Cubit has chosen to use the word ’shear.’
Shear = 1 if and only if quadrilateral is a rectangle.
The Robinson ’skew’ metric equals the ideal (zero) if the quad is a rectangle. It also attains the ideal if the quad is a trapezoid, a kite, or even triangular!
5.5.9.3 References for Quadrilateral Quality Measures
  1. (Robinson, 87)
  2. FIMESH code.
  3. Unknown.
  4. (Knupp, 00)
  5. P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
  6. 6. SDRC/IDEAS Simulation: Finite Element Modeling–User’s Guide
5.5.9.4 Details on Robinson Metrics for Quadrilaterals
The quadrilateral element quality metrics that are calculated are aspect ratio, skew, taper, element area, and stretch. The calculations are based on metrics described in (Robinson, 87). An illustration of the shape parameters is shown in Figure 370, below. The stretch metric is calculated by dividing the length of the shortest element edge divided by the length of the longest element diagonal.
Figure 370: Illustration of Quadrilateral Shape Parameters (Quality Metrics)
The metrics used for tetrahedral elements in CUBIT are summarized in the following table:
Function Name
Dimension
Full Range
Acceptable Range
Reference
Aspect Ratio Beta
L^0
1 to inf
1 to 3
1
Aspect Ratio Gamma
L^0
1 to inf
1 to 3
1
Element Volume
L^3
-inf to inf
None
1
Condition No
L^0
1 to inf
1 to 3
2
Inradius
L^1
-inf to inf
None
None
Jacobian
L^3
-inf to inf
None
2
Scaled Jacobian
L^0
-1 to 1
0.2 to 1
2
Shape
L^0
0 to 1
0.2 to 1
3
Relative Size
L^0
0 to 1
0.2 to 1
3
Shape and Size
L^0
0 to 1
0.2 to 1
3
Timestep
Seconds
0 to inf
None
4
High Order Metrics
Normalized Inradius
L^0
-1 to 1
0.15 to 1
Distortion
L^0
-1 to 1
0.6 to 1
5.5.10.1 Tetrahedral Quality Definitions
With a few exceptions, as noted below, Cubit supports quality metric calculations for linear tetrahedral elements only. When calculating quality metrics, that only support linear elements, for a higher order tetrahedral element, Cubit will only use the corner nodes of the element.
Aspect Ratio Beta: CR / (3.0 * IR) where CR = circumsphere radius, IR = inscribed sphere radius
Aspect Ratio Gamma: Srms**3 / (8.479670*V) where Srms = sqrt(Sum(Si**2)/6), Si = edge length
Element Volume: (1/6) * Jacobian at corner node
Condition No.: Condition number of the Jacobian matrix at any corner
inradius: For all tets but tetra10s, the radius of the smallest, fully contained sphere of the linear tet. For tetra10s, the mid-edge nodes are used to subdivide the tet into 12 linear sub-tets. The inradius is the smallest inradius of the 12 linear sub-tets * 2.3.
jacobian: Minimum pointwise volume at any corner. Cubit also supports Jacobian calculations for tetra15 elements.
For tetra15 elements, all 15 nodes are included for the Jacobian calculation. For all other tet types, only the corner nodes are considered.
scaled jacobian: For linear elements the minimum Jacobian divided by the lengths of 3 edge vectors
relative size: Min(J, 1/J), where J is the determinant of the weighted Jacobian matrix
shape & size: Product of Shape and Relative Size Metrics
timestep: The approximate maximum timestep that can be used with this element in explicit transient dynamics analysis. This critical time step is a function of both element geometry and material properties. To compute this metric on tets, the tets must be contained in an element block that has a material associated to it, where the material has poisson’s ratio, elastic modulus, and density defined.
5.5.10.1.1 High Order Elements
The preceding metrics will measure quality based only on the 4 corner nodes of the tetrahedron. The following metrics also take into account the mid nodes.
normalized inradius: Ratio of minimum subtet inner radius to tet outer radius (circumsphere). Subtets are defined by subdividing the tet into 12 smaller tets by using a common point at the centroid of the tet and the 6 mid-edge nodes as shown in Figure 371. The minimum in-radius of any of these 12 tets normalized by its parent outer-radius and a constant is used to determine this metric. The Normalized Inradius metric is also valid for linear elements, except that all mid-edge nodes are defined as the midpoint of their corner nodes.
Figure 371: Subtet subdivision used for determining Normalized Inradius quality metric
distortion: {min(|J|)/actual volume}*parent volume, parent volume = 1/6 for tet. Cubit also supports Distortion calculations for tetra10 elements.
For tetra10 elements, the distortion metric can be used in conjunction with the shape metric to determine whether the mid-edge nodes have caused negative Jacobians in the element. The shape metric only considers the linear (parent) element. If a tetra10 has a non-positive shape value then the element has areas of negative Jacobians. However, for elements with a positive shape metric value, if the distortion value is non-positive then the element contains negative Jacobians due to the mid-side node positions.
Note that, for tetrahedral elements, there are several definitions of the term "aspect ratio" used in literature and in software packages. Please be aware that the various definitions will not necessarily give the same or even comparable results.
5.5.10.2 References for Tetrahedral Quality Measures
  1. (Parthasarathy, 93)
  2. (Knupp, 00)
  3. P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, to appear in Finite Elements for Design
    and Analysis.
  4. Flanagan, D.P. and Belytschko, T., 1984, "Eigenvalues and Stable Time Steps for the Uniform Hexahedron and Quadrilateral," Journal of Applied Mechanics, Vol. 51, pp.35-40.
  5. SDRC/IDEAS Simulation: Finite Element Modeling - User’s Guide
To check mesh entities topology
  2. Click on Hex, Tet, Quad, Tri or Edge.
  4. Select Topology Check from the drop-down menu.
  5. Enter the appropriate value. This can also be done using the Pick Widget function.
  6. Click Apply.
Quality Check Topology [[Hex <range>] [Tet <range>] [Face <range>] [Tri <range>]]
If no entity list is given, it will check the entire model. Multiple element types are also allowed. The command checks for non-manifold boundaries (edges) in the element set entered. For quads and tris the command lists and highlights all edges that have more than two tris or faces connected.
Figure 372: Topology check for quads and tris
For hexes and tets it looks for edges with two or more elements connected that do not share common faces.
Figure 373: Topology check for hexes and tets
Additional topology checks fall into three categories:
Model Edge Check
The model edge check will find edges with adjoining quadrilaterals or triangles whose angles between the surface normals exceed a specified value. The default angle is 40 degrees.
The following commands check for model edges:
To check for model edges on volumes, surfaces and groups
  2. Click on Volume, Surface or Group.
  4. Select Model Edge Check from the drop-down menu.
  5. Enter the appropriate values for Volume ID(s), Surface ID(s) or Group ID(s). This can also be done using the Pick Widget function.
  7. Click Apply.
Topology check model edge {group|volume|surface|curve} <id_range> [angle <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
To check for model edges on blocks, sidesets and nodesets
  1. On the Command Panel, click on Analysis Groups and Materials.
  2. Click on Nodeset, Sideset or Block.
  3. Click on the Manage action button.
  5. Enter the appropriate values for Nodeset ID(s), Sideset ID(s) or Block ID(s). This can also be done using the Pick Widget function.
  7. Click Apply.
Topology check model edge {block|sideset|nodeset} <id_range> [angle <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
To check for model edges on hexes, tets, quads/faces, tris or edges
  2. Click on Hex, Tet, Quad, Trior Edge.
  5. Enter the appropriate values for Hex ID(s), Tet ID(s), Quad ID(s), Tri ID(s)or Edge ID(s). This can also be done using the Pick Widget function.
  7. Click Apply.
Topology check model edge {hex|tet|face|tri|edge} <id_range> [angle <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
The optional angle parameter allows the user to specify a custom angle value against which the check will be performed. The default angle is 40 degrees.
By default, the command will draw the model edges.
By default, very little information is output to the command line. The optional verbose parameter will output a list of the flagged model edges.
By default, the model edges will be written to the group ’model_edges’. Optionally, the user may specify no grouping, or the user may specify the name or id of an existing group into which the model edges will be written. The contents of the existing group will be replaced by the model edges. Interface Checks Cubit will verify the interfaces between sections of a model. The existence of coincident nodes, for example, may not necessarily be an error in the model if the nodes are in sliding contact or are constrained by some type of multi-point constraint. The existence of coincident quadrilaterals or triangles may indicate that the model is not correctly joined.
To check for coincident nodes.
  1. On the Command Panel, click on Mesh and then Node.
  2. Click on the Quality action button.
  3. Select Coincidence Chenck from the drop-down menu.
  4. Select Coincident Nodes, Coincident Quadrilaterals/Faces or Coincident Triangles.
  5. Enter the appropriate settings.
  6. Click Apply.
Topology check coincident node {group|volume|surface|curve|vertex} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
Topology check coincident node {block|sideset|nodeset} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
Topology check coincident node {hex|tet|face|tri|edge|node} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
The optional tolerance parameter allows the user to specify a custom tolerance value against which the check will be performed. The default tolerance is 1.0 e-6.
The default group name is ’coincident_nodes.’
All other options behave similarly to those described above under Model Edge Check.
To check for coincident quadrilaterals.
  1. On the Command Panel, click on Mesh and then Quad.
  6. Click Apply.
Topology check coincident quad {group|volume|surface} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
Topology check coincident quad {block|sideset|nodeset} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
Topology check coincident quad {hex|tet|face} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
The default group name is ’coincident_quads.’
All other optional parameters behave similarly to those described above.
To check for coincident triangles.
  1. On the Command Panel, click on Mesh and then Tri.
  6. Click Apply.
Topology check coincident tri {group|volume|surface} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
Topology check coincident tri {block|sideset|nodeset} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
Topology check coincident tri {hex|tet|face|tri} <id_range> [tolerance <value>] DRAW|nodraw|highlight] [BRIEF|verbose] [RESULT GROUP[{<name>}|{<id>}|nogroup]]
The default group name is ’coincident_tris.’
The metrics used for triangular elements in Cubit are summarized in the following table:
Function Name
Dimension
Full Range
Acceptable Range
Reference
Element Area
L^2
0 to inf
None
1
Maximum Angle
degrees
60 to 180
60 to 90
1
Minimum Angle
degrees
0 to 60
30 to 60
1
Condition No
L^0
1 to inf
1 to 1.3
2
Scaled Jacobian
L^0
-1 to 1
0.2 to 1
2
Relative Size
L^0
0 to 1
0.25 to 1
3
Shape
L^0
0 to 1
0.25 to 1
3
Shape and Size
L^0
0 to 1
0.25 to 1
3
Distortion
L^2
-1 to 1
0.6 to 1
4
5.5.12.1 Approximate Triangular Quality Definitions:
element area: (1/2) * Jacobian at corner node
maximum angle: Maximum included angle in triangle
minimum angle: Minimum included angle in triangle
condition no. Condition number of the Jacobian matrix
scaled jacobian: Minimum Jacobian divided by the lengths of 2 edge vectors
distortion: {min(|J|)/actual area}*parent area, parent area = 1/2 for triangular element
5.5.12.2 Comments on Algebraic Quality Measures
Relative Size, Shape, and Shape & Size are algebraic metrics, which have well behaved properties. Cubit encourages the use of these metrics over other metrics. These metrics are referenced to an ideal element which, in the case of triangular elements, is an equilateral triangle. Thus deviations from an equilateral triangle are measured in various ways by the algebraic metrics.
Relative size measures the size of the element vs. the size of reference element. If the element is twice or one-half the size of the reference element, the relative size is one-half. By default, the size of the reference element is the average size of all the elements that the quality command is currently evaluating.
The shape and size metric measures how both the shape and relative size of the element deviate from that of the reference element.
5.5.12.3 References for Triangular Quality Measures
  1. Traditional.
  2. Knupp, 2000.
  3. P. Knupp, Algebraic Mesh Quality Metrics for Unstructured Initial Meshes, submitted for publication.
  4. SDRC/IDEAS Simulation: Finite Element Modeling–User’s Guide
The metrics used for wedge elements in Cubit are summarized in the following table:
Function Name
Dimension
Full Range
Acceptable Range
Aspect Ratio
L^0
1 to inf
1 to 3
Element Volume
L^3
-inf to inf
None
Condition No.
L^0
1 to inf
1 to 3
Jacobian
L^3
-inf to inf
None
Scaled Jacobian
L^0
-1 to 1
0.2 to 1
Shape
L^0
0 to 1
0.2 to 1
Distortion
L^0
-1 to 1
0.6 to 1
5.5.13.1 Wedge Quality Definitions:
With a few exceptions, as noted below, Cubit supports quality metric calculations for linear wedge elements only. When calculating quality metrics (that only support linear elements) for a higher-order wedge element only the corner nodes will be used.
aspect ratio: Maximum edge length ratios at the wedge center
element volume: Calculated by dividing the wedge into 11 tetrahedron and summing the volume of each.
condition no.: Condition number of the Jacobian matrix at any corner
jacobian: Minimum pointwise volume at any corner. Cubit also supports Jacobian calculations for Wedge21elements.
scaled jacobian: Minimum Jacobian divided by the lengths of 3 edge vectors
