4.13 Geometry Deletion
To delete geometry from the model
On the Command Panel, click on Geometry.
Click on Volume, Surface, Curve or Vertex.
Select the Delete action button.
Enter in the appropriate value to be delete. This can also be done using the Pick Widget function.
Click Apply.
Delete [Body | Surface | Curve | Vertex] <id_range>
Any type of Body can be deleted, whether it is based on solid model geometry or another representation. Other entities (Surface, Curve, Vertex) can be deleted when they are "free", i.e. when they are not contained in an entity of higher topological order (Body, Surface or Curve, respectively); this type of geometry is often created from the lowest order topology up.
